MP2555
  • tcypy1961
    • 773
    #16
    Re: MP2555
    [QUOTE=luca72;2578429]iI had similar problems a couple of times on this series, it was the double thermistor that was faulty[/
    • luca72
      • Oct 2017
      • 1792
      #17
      Re: MP2555
      [QUOTE=tcypy1961;2582844]
      Originally posted by luca72
      iI had similar problems a couple of times on this series, it was the double thermistor that was faulty[/Would the thermistor cause insufficient heat; that is the temp not to reach set amount??? And this wouldn’t throw an error code???
      the answer is within your question, if the thermistor is out of tune, the controller doesn't know it, so it controls the heater based on incorrect data, (even a toner crust is enough)...however since there is a rindondance with a comparing the signals of the two upper ternistors at a distance, if the deviation remains in a certain range, the machine does not generate any code, but a toner fixing defect is produced.
      I would like to remember that the bulk of the sc codes that statistically involve the fuser unit are mostly related to over temperatures.
      "I'll be back"
      • tcypy1961
        • 773
        #18
        Re: MP2555
        [QUOTE=luca72;2582854]
        Originally posted by tcypy1961
        the answer is within your question, if the thermistor is out of tune, the controller doesn't know it, so it controls the heater based on incorrect data, (even a toner crust is enough)...however since there is a rindondance with a comparing the signals of the two upper ternistors at a distance, t if the deviation remains in a certain range, the machine does not generate any code, but a toner fixing defect is produced.
        • luca72
          • Oct 2017
          • 1792
          #19
          Re: MP2555
          [QUOTE=tcypy1961;2582863]
          "I'll be back"
