IM C6000 scan issue
  • tomcatt
    • Jul 2010
    • 93
    IM C6000 scan issue
    Documents that are scanned have a faded horizontal stripe in the middle of the page about an inch wide. Copies also but more obvious on scans. Prints are fine. I imagine it is a problem with the scanner or optical reading unit...I am wondering if anyone else has ran into this problem.
    • 37628
    Re: IM C6000 scan issue
    By horizontal do you mean in the main scan direction or the sub scan direction. And by faded do you mean slightly lighter image or a very light background stripe of some color? One other thing, does it occur off the platen glass or the document feeder?
    • mrwho
      Major Asshole!
      • 4299
      Does it make any difference when scanning from the glass or from the feeder?
      Mascan42
      Ibid
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Try scanning at different resolutions and see if the problem shifts.
        If it does, you may have a memory issue.
        On at least most if not all models, you can remove the RAM, clean the pins, and snap them back in.
        That was all it took in my case.
        Good luck!
        • tomcatt
          • Jul 2010
          • 93
          I have attached example. Scanned off of the glass. Change in resolution does not help.
          • davel
            • Oct 2011
            • 1108
            Clean the optics. I have no experience on production models.
            • anothertech
              • 1771
              What have you done so far? Clean the optics and clean the laser slit glass. If still a problem, copy single color to narrow down problem.
                • 37628
                Looks to me like you have a bright spot on the scanner LED lamp assembly. Auto Color Calibration, copier portion, might be able to correct it.
                For the best image quality, this is done during installation and should be done periodically by the customer. It is accessed with the "Settings" as follows.
                Settings -> Machine Features Settings -> Maintenance -> Auto Color Calibration
                At one time Ricoh recommended doing this after every firmware update with the Metis 1, MP Cxx03 series.
                • copyboy99
                  • Jan 2020
                  • 24
                  Hi,
                  we have had few calls on these IM Cxxxx series with similar scanning issue, resolved by replacing BCU/BICU (D0BQ5114)
                  • Gift
                    • Mar 2011
                    • 2459
                    I agree, start cleaning the optics and CCD element (carefully). Unfortunately the integrated scanner carriage assy is not as idiot proof to handle compared to the old style scanner design. If the machine is pretty new you can also try using compressed air first.
                    • luca72
                      • Oct 2017
                      • 1792
                      yes, look, someone probably had the bad idea of adding a lubricant that was too thin to the (almost central) axis of the carriage, and he during the run was sprayed on the mirror, in fact the defect is almost in the center.
                      you should clean the small mirror hidden near the lens of the carriage, it's a bit difficult to reach, in fact I built myself a tool to effectively clean the optics of that series without swearing, using a piece of plastic, a rag and a couple of pieces of polystyrene to make it soft and adaptable to all inclined surfaces, (the cigarette is there to give the proportions).
                      "I'll be back"
