Mpc 2500/3000 mpc 3500 firmware
  • mikadonovan
    • May 2008
    • 2937
    Hey guys (and gals),
    We have just ordered 3 color copiers, mpc2500,mpc3000 and a mpc3500( B230, B237, B222) with very low serial numbers which means the firmware is probably not up to date on any of them. In an attempt to prevent related service troubles I sure would like to have the latest versions to load when they arrive.
    If anyone has this handy, and it's not too much trouble, I would be grateful for them sent to me by email. Thanks in advance.
    Let me know if I can be of help to you.
    mikadonovan@yahoo.com
    NEVER ASSUME ANYTHING
  • Jomama46
    • 2900
    check your email in about an hour
    sigpic
    A+; Network +; PDI+
    • mikadonovan
      • May 2008
      • 2937
      Superb download. Thanks again and have a great weekend!
      • Jomama46
        • 2900
        We'll its still raining so I wont have to cut the grass.
        Guess I'll just stay home and play with the kids mom.
        sigpic
        A+; Network +; PDI+
        • tcs04
          FORMER Techie
          • 1183
          Your dog still looks like it needs a walk!
          • Jomama46
            • 2900
            naw, he's just a crazy little bastard!
            But he keeps the cats on their toes!
            sigpic
            A+; Network +; PDI+
            • nirvan45
              • May 2011
              • 5
              Jomama
              I can see posts to this thread is over 2yrs to date.
              I am in a jam for this weekend and have machine to deliver for this week.
              I requested firmware upgrade for ricoh mpc3500 from vendor and it seems like they forgot to send me complete files.
              As it stands I have five files and seems like missing the main activating file or bin extension.
              I see you were kind enough to email it to first post.
              Is there any chance doing the same for this weekend?
              Thanks in advance
              And hope all have a great memorial weekend
              • totoro
                • 568
                There is no activating file or bin extentions. Are your files .fwu files, or .rfu files? If so, do the remote firmware upgrade using the .rfu files, and use the SD card with the .fwu files.
                Totoro
                • nirvan45
                  • May 2011
                  • 5
                  Thanks for reply
                  All five files are with fwu extension
                  I am using a 2gig sd CARD formatted it to fat 16
                  Created a root directory of romdata, subdirectory of b222, copied 5 files in b222 folder.
                  Insert the sd card in the unit and get a sc819 error.
                  Now any other help will be appreciated.
                  BTW: do not have access to files doing a remote upgrade.
                  Also can not find any smaller sd card at this time, and been told by the vendor that they have done upgrade w/ 2 gig card
                  EDIT: problem w/ unit is when it is idleing it freeze and have to do a power shut down, or sometimes it freeze right on first screen upon power on.
                  • TonerMunkeh
                    Professional Moron
                    • 3873
                    2gig is too big, hence the 819. Controller board could also be fried.
                    Hit it.
                    • nirvan45
                      • May 2011
                      • 5
                      besides the above symptoms, copier works fine.
                      After removing sd card, on power on functions the way it should.
                      Well anyone can send me rfu files, I can proceed that way
                      • totoro
                        • 568
                        Try putting the files directly into the romdata folder and deleting the b222 folder. I have had issues with the sub folders being used. What brand of SD card are you using? The machines don't seem to like no-name or knock-off brands. If it is a well known brand name card then then you might want to try a different brand. I will post back if I can think of anything else.
                        Totoro
                        • nirvan45
                          • May 2011
                          • 5
                          Thanks guys
                          I really appreciate responding in a wkend like this one.
                          as you all may know 2 gig is the smallest one I can find off the shelf.
                          Looking through ebay for smaller, but will take a few days to get in.
                          using a patriot memory for now, will look to a sandisk.
                          Try to partition it smaller size to get away, but no such option available.
                          Thanks again
                          I also tried it in root directory of romdata w/ same result
                          Going to try a few options today, any more tip will be greatful.
                          • teebee1234
                            • Jul 2008
                            • 1670
                            I think TonerMunkeh is correct as far as the controller being the issue, but I've used 2g cards exclusively with no problem. Here is Global Knowledge Base answer regarding the SC819 on this model....
                            SC819 occurs
                            [Symptom]
                            SC819 occurs.
                            SC670 and 991 are also logged on multiple occasions.
                            SC819: Kernel stopped
                            • SCS process ended for some unknown reason. gwinit process ends (gwinit specification), kernel errors and stops (kernel specification).
                            • In the case of system processes using too much RAM. In the case of the CPU cache error TRAP occurring.
                            • If a mismatch is detected inside the OS.
                            [Cause]
                            Controller board
                            Removing and replacing the HDD and controller temporarily restores the device with copy, fax and printer functions all normal but after turning the power off and on a few times and awakening from preheating, the problem reoccurs at the Please Wait screen (remote diagnostic device error also occurs).
                            [Resolution]
                            Replace controller. After replacing, initialize and write the RC Gate certificate.
                            Replacing the HDD does not solve it (this is a temporary fix so the address book can be backed up and restore performed after replacing the HDD)
                            *Found a tech bulletin in regards to SD card size, turns out 2G is the maximum supported
                            • nirvan45
                              • May 2011
                              • 5
                              Thanks again everyone for being helpful
                              Wow who would have think
                              Considering low memory sd cards are gone to lala land for a few yrs, you think they would upgrade interface on these boards to accept larger sd cards.
                              My problem was the size of sd card
                              Took a sd card from another machine size 32 meg cleaned and loaded the firmware, proceeded to upgrade with no problem.
