Ricoh mp2555 fuser follow up
  • tcypy1961
    • 773
    [Misc] Ricoh mp2555 fuser follow up
  • Codex
    • May 2008
    • 705
    Re: Ricoh mp2555 fuser follow up
    Hello
    Try to increase the Print ready temp. Clean the thermopile and check thermistors, it's easy to mount the thermistors upside down (had this once, the customer tried "do it yourself")
    Is the sleeve correct for this model?
    Inviato dal mio SM-S901B utilizzando Tapatalk
    Memento Audere Semper
    • luca72
      • Oct 2017
      • 1792
      have you tried replacing the contact thermistors, I had a similar problem months ago, and I solved it like this, I tend to think that the fact of having to modify the working temperatures via sp is not a good idea, in the sense that it means that there is an upstream problem that we try to resolve in a roundabout way. however, if you have the possibility, the ideal would be to try replacing the entire fuser unit with another one, even a used one, just as a test
      "I'll be back"
