Ricoh fd3010 folding unit
  • jumpinj18
    • Oct 2023
    • 9
    [Misc] Ricoh fd3010 folding unit
    Does anyone know what the differences are between ricoh FD3010 and FD3020? And will the FD3010 work in the IM C3510?
  • Saturn
    • Nov 2023
    • 171
    Re: Ricoh fd3010 folding unit
    In the past, some options differed only in the color of the covers, but worked without any problems in the successor models. I would give it a try.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • jumpinj18
      • Oct 2023
      • 9
      Yeah I know, I was just hoping someone had done it before I order one for a customer. Thank you.
        • 37446
        Download the parts catalogs from rfg-esource and compare them. If the covers are the only thing that is different, you're in. The only other item that would not be a big problem is the firmware on the eeprom. Sometimes you can firmware update module to correct it or just order the pone in the parts catalog.
        • anothertech
          • 1766
          Why would you order the one that doesn't fit?
            • 37446
            Usually with finishers for Ricoh, fitting is not the problem. Compatible electronics package is.
            • jumpinj18
              • Oct 2023
              • 9
              Didn't, found out they needed it after ordered and delivered.
              • dalewb74
                • Feb 2018
                • 1143
                ever used the ricoh online configurator?
                • jumpinj18
                  • Oct 2023
                  • 9
                  I've used configurator. I've done all those things. I have a customer with budget constraints and wanted to know if anyone has tried using the 3010 in place of the 3020. Because i don't have a machine in shop to test it on and i don't want to test it in the field.
