IMC3500. screen remote
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    Customer has 4 x IMC3000's, their ICT department regularly takes over the screen at remote.
    It works on 3 machines, one however gives an error 5000 (?)
    someone familiair with this error code?
    Thanks in advance
    • 37488
    Re: IMC3500. screen remote
    Is that error ob the IM C3500 or the computer trying to access it?
    • GeorgeBest
      • Jul 2009
      • 526
      From what he told me I did understand that is was coming from his PC
      But as I said, the other IMC's worked allright . . .
        • 37488
        The 5000 error is a generic internal error code. Unfortunately, it could mean one of many things. Could be a problem at the C3500 such as a jam of some type or a Service Code. It could have something to do with the settings of that machine or there may have been someone using it in such a way as to temporarily block remote screen access.
        • Saturn
          • Nov 2023
          • 171
          Do all machines have the same SOP firmware version?
          The SOP Firmware is called M2a_System at the Diagnostic Report 5-990-005.
          I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
          • dalewb74
            • Feb 2018
            • 1153
            yeah ricoh is bad about that. saying it can't do one thing, because something else is still in the process of doing whatever. it is annoying.
              • 37488
              What is infuriating is standing in front of the machine working on a major project and have asshole take over control remotely.
              • copier tech
                • 8144
                Originally posted by GeorgeBest
                Hi,
                Thanks in advance
                Update the firmware on the device not working / check they are on the same version.
                We occasionally run into this, sometimes simply restarting the Ricoh will resolve the issue.
                • dalewb74
                  • Feb 2018
                  • 1153
                  yes indeed!!
