SC672-20
  • Suppotech
    • Jun 2023
    • 11
    SC672-20
    Hello everyone
    I have 03 COPIERS RICOH
    IM 350
    IM C2000
    IM C300
    installed IN different customers with meters between 20,000 and 30,000
    the copiers display error code SC672-20
    refuse access to SERVICE MODE
    refuse to update FIRMWARE
  • MIKON
    • Jul 2015
    • 188
    Re: SC672-20
    Usually it's the controller
    • Saturn
      • Nov 2023
      • 171
      Re: SC672-20
      In 80% of the issues you have to replace the controller as MIKON says. In some cases it's the operation panel pcb.
      If you activate ARFU during installation, this will significantly reduce the number of faults.
      I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • fshead
        • 2376
        Re: SC672-20
        i hate that code and had many mpc401s with it,control panel,connector usb to brd,firmware and the controller..
        the issue too is if you check service code history that code never shows up...so you cant know b4 picking up these headaches...
        • hnami
          service technician
          • Nov 2023
          • 169
          Re: SC672-20
          try this
          replace hdd drive
          • Suppotech
            • Jun 2023
            • 11
            Re: SC672-20
            I have already replaced the Hard Drive.
            the same problem remains.
              • 37532
              Re: SC672-20
              Smart Operation Panel communicates with the controller via the USB cable [Fig.1-A] and harness
              [Fig.1-B]. Have you tried replacing or at least reseating them?
              • copier tech
                • 8172
                Re: SC672-20
                Originally posted by Suppotech
                Hello everyone
                IM 350
                IM C2000
                IM C300
                Since you can't enter SP mode or update firmware they only option is to replace the controller board.
                We fit used one for this code, just remember to swap over the NVram.
                • fshead
                  • 2376
                  Re: SC672-20
                  for me sometimes the sc 672 takes a while to pop up and you can try updating via ricoh FW CLU PROGRAM VIA IP address.
                  it might code out during update like it did for me but i was able to do FW updates eventually...I cant see HDD being issue and if able pull HDD and test it on a external docking bay...
                  • Suppotech
                    • Jun 2023
                    • 11
                    Re: SC672-20
                    I would like to thank everyone for their support.
