Ricoh 2011 color test failed
  • Kotkey
    • Mar 2024
    • 16
    Hello! My Ricoh MPC2011 failed pattern color test page in service menu SP 1-103-002. Prints test gradation good SP1-103-001! Prints calibration from the custom menu good. For what reasons did you fail color test SP1-103-002 in the service menu?
  • luca72
    • Oct 2017
    • 1719
    Re: Ricoh 2011 color test failed
    Originally posted by Kotkey
    Hello! My Ricoh mpc2011 failed pattern color test page in service menu SP 1-103-002. Prints test gradation good SP1-103-001! Prints calibration from the пользовательское меню good. For what reasons did you fail color test SP1-103-002 in the service menu?
    • Kotkey
      • Mar 2024
      • 16
      Thank you! I am grateful to you! But everything was fine until I installed the transfer belt and closed the right swing arm down. Then I did sp 2-111-03-02-01. I got error sc285 and sc 492. I turned the levers down from the left and right on the transfer belt, did sp 2-111-03-02-01 again, everything became fine, but color test page failed...
      • luca72
        • Oct 2017
        • 1719
        maybe there could be a problem with the mobile shutter of the id sensors that doesn't open correctly, try to check it, it seems to me that it doesn't have hp sensors, so I think it can also be removed, but check
          • 37110
          There could be a problem with the ITB latch cam. It is located on the back end of the shaft the "swing arm" is mounted. This will allow the end of the ITB closest to the ID sensor to move slightly when the solenoid that controls the shutter is energized. This results in SC285.
          Since the ITB is not fully locked in, there may not be proper connection to the ITB for the HVPS. This could be the cause of the SC492.
          • Kotkey
            • Mar 2024
            • 16
            If you mean line d, then in what order should I make the adjustment SP 2-111-01, -02,03,04 (line a, b, c, d) so that it would be correct?
              • 37110
              NO, he means the physical slide plate of the ID sensor assembly mount bracket. Removing it might help.
              As for SP 2111, If you use a you don't need b as a run b twice. If you use d you don't need c as c is part of d. The documentation is not clear as to whether s run c then a or c then b. If it includes a, then all you have to run is d. If it includes b then you need to run d then b.
              • Kotkey
                • Mar 2024
                • 16
                Many thanks to everyone who answered me! I want to ask, do sc285 and sc 492 need to be reset? Erase from memory? Or if everything goes well, will they disappear on their own?
                  • 37110
                  They will disappear once the problem causing them is repaired.
                  • Kotkey
                    • Mar 2024
                    • 16
                    The color test page prints well! I turned on auto-select paper tray 1. It stood - not to show.
                    • Kotkey
                      • Mar 2024
                      • 16
                      My black one started printing with white stripes! I did a forced toner supple
                      this doesn't help. I showed it in the photo. Is this a bad PCU?
                      • luca72
                        • Oct 2017
                        • 1719
                        At Eye seem of yes, but you can check from you self if you print the PM status from sp menu, so you can see the pcu Life status
                        • Kotkey
                          • Mar 2024
                          • 16
                          I will be grateful if you tell me what the number of this SP is! I didn't know that this could be checked via SP.I will be grateful if you tell me what the number of this SP is! I didn't know that this could be checked via SP.
                          • luca72
                            • Oct 2017
                            • 1719
                            No Number, its in sp main menu, One last voice, called [PM COUNTER STATUS]
