Prints from computer are washed in black.
    • 37532
    #16
    Re: Prints from computer are washed in black.
    Originally posted by PressingPrintz
    Yes of course. That was one of the first things we tried.
    All the optics including the mirrors, the lamp reflectors and the lens? Did you test to see if the mirrors were clean with a captain's pen light? Did you run copy portion of ACC before attempting to do the printer portions?
    • PressingPrintz
      • Nov 2022
      • 74
      #17
        • 37532
        #18
        [QUOTE=PressingPrintz;2587170]
        • PressingPrintz
          • Nov 2022
          • 74
          #19
          [QUOTE=slimslob;2587174]After running 5801-008 it appears now even the internal test prints are coming out washed in black. However, it appears the lines have almost a digital pattern to them.
          • PressingPrintz
            • Nov 2022
            • 74
            #20
            • KeviM
              • Oct 2019
              • 324
              #21
              Hello. I'd try the following in this order
              1) service your laser unit
              2) replace your black developer unit
              3) replace your black drum unit
              All the best friend
              • PressingPrintz
                • Nov 2022
                • 74
                #22
                  • 37532
                  #23
                  If it is a setting issue it is a setting for something that was replaced after it left the factory such as the ID sensor. New ID sensor boards come with a sticker that has the required information. If you are lucky that sticker might be attached to the frame above the board or on the inside of a door.
                  • luca72
                    • Oct 2017
                    • 1784
                    #24
                    really a fucking problem! prints badly from USB...apart from a stroke of luck...the only thing to solve it in a reasonable time without wasting time and fuel, its retire the machine in the laboratory, place it alongside another identical unit, and start to Exchange parts at go-go...sometimes there are no other roads.
                    "I'll be back"
                    • PressingPrintz
                      • Nov 2022
                      • 74
                      #25
                      • PressingPrintz
                        • Nov 2022
                        • 74
                        #26
                        • semi
                          • Sep 2008
                          • 195
                          #27
                          [QUOTE=PressingPrintz;2587697]
                            • 37532
                            #28
                            [QUOTE=semi;2587699]NOT. He has already reentered everything from the birth certificate which corrects everything cleared by memory clear. Gamma setting can only get mese3d up if someone actually changes them. And that can be fixed by clearing printer function.
                            • PressingPrintz
                              • Nov 2022
                              • 74
                              #29
                              Forgot to attach the image.
                              • PressingPrintz
                                • Nov 2022
                                • 74
                                #30
                                [QUOTE=slimslob;2587703]
