Prints from computer are washed in black.
  • PressingPrintz
    • Nov 2022
    • 74
    [CQ] Prints from computer are washed in black.
    Hello again,
    It seems whenever something is printed from a direct USB computer, they are washed in black. This includes different file types (PDF, image files, vector, etc).
    However when printing a quality page internally it comes out looking clean. Any ideas what setting is causing this?
  • PressingPrintz
    • Nov 2022
    • 74
    Re: Prints from computer are washed in black.
    I forgot to include the model- MP C3002.
    • dalewb74
      • Feb 2018
      • 1157
      printer driver? new usb cable? different port on the PC? that's where i would start. rule out the simple things.
      • PressingPrintz
        • Nov 2022
        • 74
        Tried multiple USB Cables- no change. They're using the correct Ricoh drivers.
        Also forgot to mention- its the same result if printing off of a thumb drive directly plugged into the machine.
        • PressingPrintz
          • Nov 2022
          • 74
          The machine recently had all it's SP settings cleared. After all the door settings were put back in it seems the test prints are back to normal. Just anything other than the test print page seems to be washed out in black.
            • 37532
            Check to see if Toner Save is enabled. Can't remember if it is in User Tools - Printer Features or a driver setting.
            • ccchuah
              • Mar 2009
              • 157
              Did it happens when printing in black and white ? Try replacing the black PCDU if only happen only in color and not mono copy.
              • luca72
                • Oct 2017
                • 1784
                Originally posted by PressingPrintz
                Hello again,
                try to disable and enable the usb port by SP, and upgrade the firmware
                "I'll be back"
                • PressingPrintz
                  • Nov 2022
                  • 74
                    • 37532
                    Then run Auto Color Control in User Tools - Maintenance
                    • PressingPrintz
                      • Nov 2022
                      • 74
                      • PressingPrintz
                        • Nov 2022
                        • 74
                        I am able to get it to run Clayton color calibration only on 1200x1200 dpi. It fails at all other resolutions.
                        • PressingPrintz
                          • Nov 2022
                          • 74
                          Correction- Auto color calibration
                          • davel
                            • Oct 2011
                            • 1107
                            Have you cleaned the optics?
                            • PressingPrintz
                              • Nov 2022
                              • 74
                              Yes of course. That was one of the first things we tried.
