Sc 101 aficio 1060
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    #31
    have you swap the PSU to other working same machine model? or fusing unit assembly?
    fix the customer first then fix the machine... its simple and makes life more easy.
    • Guicho
      • May 2009
      • 17
      #32
      no always has been in the same 1060.
      • stephend
        Senior Technician
        • 306
        #33
        Hi Guicho,
        you did a great job until now...of course all of us...we are interested in the result (or at least I am). Maybe it's time to try a different power supply from a working machine. SC 543 is usually the non contact thermistor and in the worst case the BCU.
        Also check the high voltage board for corona unit..for that weird black bands problem.
        • Guicho
          • May 2009
          • 17
          #34
          Originally posted by stephend
          Hi Guicho,
          Estimated friend:
          News for late hour:
          Sc672 Controller Board Stalled
          • stephend
            Senior Technician
            • 306
            #35
            Estimated friend:
            News for late hour:
            Hey...calm down..for a sec...
            It's this one the original Controller??? . Check all the connectors maybe is something not connected properly. Hope no wires are pinched.
            And hope that you didn't modified the #6 on DIP SW 101 because was correct.
            Do you have a NV RAM back up since your machine was new or in a working state? If yes...format your HDD and RAM Clear and start fresh.
            • Guicho
              • May 2009
              • 17
              #36
              • stephend
                Senior Technician
                • 306
                #37
                Ok...but don't be desperate...Everything can be fixed...Of course another tech it's a great thing to have...It will give you confidence and you know another set of eyes it's always welcome
                If you don't have the birth certificate for this machine...you can "clone" one from a different one and do adjustments after....
                Viva Mexico my friend and good luck tomorrow.
                • imaginemoko
                  unTrusted Tech
                  • Jan 2008
                  • 289
                  #38
                  meaning fuse 111 was blown again? i guess we have pinch wire here... am thinking this web motor and corona cleaner motor may one of them is defective...
                  • Fearless V K
                    • 620
                    #39
                    The wires at the rear of the fusing unit will often short to the frame when the fuser is pushed in. Check those. Try turning the machine on with the door open and fuser pulled out and see if anything different happens. Make sure all fuses are good on the PSU, then try pulling connectors one at a time and see if the machine comes back. You'd be surprised how much stuff you can strip off these and still get them to come on.
                    Faulty power supplies can cause strange problems also. They don't necessarily have to be dead to malfunction. They may be outputting spiky voltages that can interfere with digital logic levels.
                    Don't take that toner with me!
                    • francisco
                      • Nov 2009
                      • 168
                      #40
                      Re: Sc 101 aficio 1060
                      Hy did you solve this problema
                      y have exactly the same issue (sc 101 )
                        • 37500
                        #41
                        Start a new thread.
                        • KOPYTEK55
                          • Nov 2009
                          • 21
                          #42
                          Check that the screws on the fly wheel are not loose
