Aficio 1045 sc326
  • Bob
    • Aug 2025
    Aficio 1045 sc326
    Rcv fax ok, rcv prints ok, select copy & press start paper gets to registration rollers and sc 326 is generated. Changed the LD unit and got same results. Any hepl would be appreciated.
  • YHEL23
    • Nov 2008
    • 146
    Try this tb..Hope can help..Good luck
    DYNAMIC OFFICE SOLUTIONS
    • stephend
      Senior Technician
      • 306
      So you can print 1000 sheets and no sc 326?
      It happen only in copy mode?
      And everything else mechanically is in a good shape I suppose...clutches, feed tires, mylars, etc...
      Did you replaced the LD unit with a new one?...or just poly motor.
      Check the connection between LD sync board and the LD unit itself. Also check the connection between LD unit and BICU. Change the BICU from other machine....first back up NVRam before you start.
      • Bob
        I put a known good laser unit in the machine , did laser beam pitch adjustment. Same end result, fax ok, print ok, and copy no go.
        • stephend
          Senior Technician
          • 306
          If you can send out faxes...your HDD and optical system is good. If you can print your laser unit it's working fine.
          Try to replace the BICU. Back up NVRam & address book first, replace the BICU, do a 5801 and start from the scratch.
          • Fearless V K
            • 620
            Door switches? These can cause strange problems.
            Don't take that toner with me!
            • imaginemoko
              unTrusted Tech
              • Jan 2008
              • 289
              agree... try to check micro switches... and clean the sync detector... bring spare...
              fix the customer first then fix the machine... its simple and makes life more easy.
              • MaiHoang
                Aficio AF 1035 copy not go. Replaced poly motor - now SC 322 code. Pls help me . Thanks a lot .
                • Paper_Jam
                  Expecting a call.
                  • Jun 2007
                  • 101
                  I think someone else said it too in this thread, replace the door switches!
                  • tcs04
                    FORMER Techie
                    • 1183
                    The ones above the fuser! Has the machine been leaking toner? If so. this will blow over the switches.
                    • MaiHoang
                      I did and it ok - Thanks of all.
                      • max toby
                        • Jul 2008
                        • 20
                        Well....
                        What happened? was it the door switches? was it the ribbon cable? what happened, I need to know too. Also, can anyone tell me what happened to Scanrouter V2 Lite? and if V2 Lite is gone,which version are you supposed to use now? I guess i sound like i fell off the turnip truck, but I am really just short of screwed here. Sounds like an LD unit to me, but they are like 500 bucks or something. Not even worth it in my books. But hey, I just fix em.
                        Peace
                        Max
                        • max toby
                          • Jul 2008
                          • 20
                          well...
                          I tried the door switch idea, with no sucess. And I changed em all. One one of the machines I tried the LD Pitch adjustment 2-103-1,2,3,4 all set back to default, and no 326 so far. Here's hoping.
                          Thanks, and I'll keep you posted.
                          Peace
                          Max
