customer had comptrs worked on now getting error cannot update server . ok got rid of that but stays in update mode whtas the problem?
ricoh 1075
Cust. may have added or updated firewall or antivirus programs that are blocking access. Authentication passwords may have changed. IP addresses may have changed.Don't take that toner with me! -
does the network on DHCP? on scanning the scanrouter where the scanfolder directed or addressed was changed due to the dhcp log ip issuance... or maybe the scanrouter is suspended.
i hope it could helpfix the customer first then fix the machine... its simple and makes life more easy.Comment
i assume sir that you are reffering to the machine it self.... maybe we have a dchp network that may cause our problem...fix the customer first then fix the machine... its simple and makes life more easy.Comment
I would also look at anything they did when they had the computers worked on. Talk to the IT people who of course will never admit that they caused the issue.
Also since they have already told you that they had the computers worked on and now it doesn't work, in our company that is a chargable call. Bill 'em good!!!sigpic
Relax! This firmware injection won't hurt...but it will take 45 minutes.
We are talking about a ScanRouter setup correct? I had this issue recently when they changed the IP address on the Delivery server computer. The computer with the ScanRouter software needs to have a STATIC IP as does the copier. TCP Port #3670 needs to be open on the delivery server as well. Make sure that the ScanRouter services are in operation. You should remove the IO device and re add it to Scanrouter if the computer being used as the server has a different IP addy now.
KerrCHING!!! $$$$$Comment
right
got the it guy out there informed him they were responsible for problem and between the two of us corrected the problem.thanks to all . all your sugestions were helpful.Comment
