After firmware upload display show pleas wait...
  • joher
    • 43
    Dear All,
    I have Rico 1350 its machine is working properly I installed a system copy firmware 6.03 and firmware instaled properly
    Now when I turn on the machine the message is please wait....
    Regard
    joher
  • daveyball
    • May 2009
    • 314
    You must install all the firmware for all the options you have on the machine, i.e. finisher, interposer etc. First install the system firwmare, and reboot the machine. Yes it takes time to comeup, can be upto 10mins, then the engine firmware, and reboot, again will tiake time to come up. The install all the other option firmeare. I rebooted after each item. Ricoh reccomend you upgrade to the Pro range of firmware as well. The whole job can take up to 90 mins but it works.
    • daveyball
      • May 2009
      • 314
      Sorry quick ammendmentto my previous post, you must upgrade the ENGINE firmware first, not the SYSTEM (very important), and proceed as previosly mentioned.
      • joher
        • 43
        now machine is pleas wait and cannot accept also service card
        • daveyball
          • May 2009
          • 314
          Is the SD card over 1gb, they don't like them. I have had the very same problem after installing the system firmware first. Ricoh say you have to take the system card for another machine, and boot from that. Then do the upgrade, I manged to downgrade the machine to the earlier firemware version, then run the upgrade, using the engine firmware first, reboot then system etc etc. Ricoh said this shopudn't havce worked but it did.
          • joher
            • 43
            i have also another machine system card and i put the machine but machine show same behave...
            machine enter only made 1993 stop key five time and nothing do anything
            i also reset through dip switch but machine is stil pleas wait....
            • daveyball
              • May 2009
              • 314
              Try to downgrade the firmware to an earlier release, preferbaly the one you upgraded from. I have done the engine frimware with a laptop using the web interface before, but then carried on using the SD card
              • joher
                • 43
                Yea but now there machine is not initialize that why network card is disable and I cant do this,
                How do I reinstall the older system copy firmware and resolve this problum...
                thankx for your qiuck reply
                • daveyball
                  • May 2009
                  • 314
                  Use the SD card then, but the machine does take a while to boot up (can be 10 mins)
                  • joher
                    • 43
                    now machine is on last 30 minats and machine is stil pleas wait.....
                    ADF light is on and finisher and paper bank is rotation normaly but when we open front dore of machine machine cannot show dore open indication,
                    • iMind
                      Vacuum Cleaning Expert
                      • Mar 2008
                      • 1116
                      • FRIDGEMAGNET
                        • Aug 2007
                        • 377
                        You need to replace the system sd card with a new one or get one from another working machine.
                        Then update every bit of firmware on the machine starting with the engine.
                        • joher
                          • 43
                          FRIDGEMAGNET i also do that..
                          • KopyKat
                            Nurse Ratched of Repair
                            • Nov 2008
                            • 365
                            READ This!!!
                            Originally posted by joher
                            Dear All,
                            Regard
                            joher
                            Engine and system must be updated SIMULTANEOUSLY then reboot then load all the other firmware one at a time.
                            I've done several with no problems...just jinxed myself.
                            Just read the attached...
                            sigpic
                            Relax! This firmware injection won't hurt...but it will take 45 minutes.
                            • KopyKat
                              • Nov 2008
                              • 365
                              ENGINE and SYSTEM simultaneously first!! Then reboot and load all other individually.
                              sigpic
