Question on dual hard drive machines
  • Star
    Ricoh Tech
    • 127
    On machines with dual hard drives (let's say the MPC4500 for example), Ricoh wants to sell the hard drives as a single unit--> B2235090 Hard Drive Unit. They want an arm and a leg for this unit (2 common hard drives mounted in the bracket) for the OUTRAGIOUS COST OF 670.07!!!
    I have been lucky enough not to have to change any drives in these machines yet. So my question is: When the time comes, is there any reason why I couldn't just aquire 2 like hard drives at the same capacity or a little larger, and use them?
    I appreciate any opinions from you Ricoh Masters out there who have experience with this?
    Thank you very much in advance!!
    Star
  • Vulkor
    • Jun 2009
    • 946
    Not sure on DUAL HD machines,but can't see why you just can't get another HD same size.
      • 23009
      The TASKalfa CS-500ci has dual hard drives and they also are sold as a pair. The reasoning I heard in class was that they are somehow selected for compatability. =^..^=
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        on the Toshiba side (actually a ricoh) the reason is that it is a raid set that needs to be set up at factory and not able to be done in the field.
        • rthonpm
          • Aug 2007
          • 2859
          Similar to what Spock said, I've heard that they are formatted in a way that there is something on them from the factory that the machine looks for to boot.
          • daveyball
            • May 2009
            • 314
            I have replaced quite a few HDD's, and have never purchased them from Ricoh (too pricey) get one from a local source. As regards size, I have replaced 40gb with 80gb etc with no probs. As long as they are not smaller you should have no issues
            • can06
              • 22
              aficio 2075
              shortly i meant, i can flip the paper face up and down in the glass copy, i can flip the paper face up and down in the bypass copy but whenever i try to use the SADF copy mode i got the copy product only one type, the copied face is down, i can not change mode to that copied face up in ADF copying. since machine's digital menu is German, i can not understand how to adjust that option. please help..
              RICOH Pro C900s
              • Jomama46
                • 2900
                Originally posted by can06
                aficio 2075
                Dont do drugs unless you have enough for everyone. It is important for us all to stay in phase.
                On the subject tho, the dual drives, as mentioned, are in a RAID array and must be replaced as a pair and not just any pair, OEM.
                I too have replaced many single drives with off the shelf but this wont work with the dual drives.
                sigpic
                A+; Network +; PDI+
                • daveyball
                  • May 2009
                  • 314
                  Yes I agree always replace the two together, but I have never had to replace with OEM ones, just off the shelf, about a fifth of price
                  • Vulkor
                    • Jun 2009
                    • 946
                    $670!! As much as these HD fail in these units, that is crazy!
                    • banginbishop
                      grumpy old git
                      • Oct 2007
                      • 894
                      There was a previous post on here some time ago. Cipher has changed them with non oem hard drives with success. Have a read through it if its any help.
                      http://www.copytechnet.com/forums/ri...p4000-hdd.html
                      Incontinentia Buttocks
                      • RicohTech_TurksCaicos
                        • Aug 2008
                        • 55
                        On the pro906ex Raid SATA 160gb drives. I have replaced them with 2 same size Western digital caviar drives Model wd1600AAJS and formatted them and had they worked fine.
                        • Vulkor
                          • Jun 2009
                          • 946
                          Good to know, I'm sure the same is Applicable for the Savin 8090's
                          • df3036
                            • 109
                            Was having HDD error's with an MP9000 dual drive m/c. Machine was down and needed to get it running. I ended up just swapping the SATA cables and the machine was up and running again. Doc server stuff gone but everything was working. That was about a year ago and have not had the problem again.
                            Kittens give Morbo gas.
                            A+, Network+, Server+, PDI+
                            • limo
                              • Jun 2008
                              • 103
                              What about the 4 hdd assembly like in venus?
                              What you can do is that you can reblace the first failure with an original assembly and then use the good parts from that unit to fix other cases.
                              Normally one hdd from the unit is defective.
