mpc4500 adding tonr
  • spaceman99
    • Jul 2009
    • 174
    mpc4500 adding tonr
    Each time u open any door I get adding toner. Sounds like its from the blk toner. replaced pump, dv assy, drum, irf pcb. Cleaned pipe and toner hoppers. Still getting it. No spillage in mch. mch works fine after it thinks its loaded.
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 366
    Narrow it down to which unit is at fault. You can't troubleshoot a problem unless you KNOW for a fact which unit is causing it.
    Then check the RJ45 connector on the back frame and the unit. They have been known for getting damaged when installing the units.
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • spaceman99
      • Jul 2009
      • 174
      Thank you for your reply.
      It is the black toner that is trying to load.
      • Eric1968
        • 2458
        Maybe a dumb question, but did you try another toner?
        • gernah
          • Jun 2009
          • 57
          Sir this is the solution of your problem:
          step 1: change new toner cartridge
          step 2:clean the toner end sensor at the back side of the machine your problem its solve easy.
          • spaceman99
            • Jul 2009
            • 174
            Thank you for your replys.
            I have already replaced the toner and striped and cleand toner end sensor.
            • imaginemoko
              unTrusted Tech
              • Jan 2008
              • 289
              if after replacing toner bottle, opc, toner pump, dev assy and still its loading toner? how about not just cleaning the toner end sensor, replace it if could help... i assume that sp modes are not change... sp 3 102= 5 try to adjust..... good luck...
              fix the customer first then fix the machine... its simple and makes life more easy.
              • ppetr
                • May 2009
                • 9
                Toner bottles full although they are empty actually
                I have a similar problem - machine is loading toner after every closing the door etc., but in addition ... in SYSTEM STATUS you can see toner bottles are full although they are empty actually. All colours.
                • Fearless V K
                  • 620
                  Have you tried upgrading/reloading firmware?
                  Don't take that toner with me!
                  • spaceman99
                    • Jul 2009
                    • 174
                    adding Toner MPC4500
                    Thank you all for replying. UPDATE: Have upgraded firmware. Changed toner end sensor. Waiting for controller PCA to come. OH..have also relaoded ROM Data.
                    • rsyarcia
                      Hair Straightener Tech
                      • 711
                      hi
                      I encountered this problem many times with black toner (MP C2500), what I did is just cleaned the host(tube) from the toner to the black dev't unit. The toner tends to get stuck on the host(tube) because on the middle it is elevated. Just try this!!!
                      Nobody is perfect..
                      • Cipher
                        It's not easy being green
                        • May 2006
                        • 1309
                        +1
                        I've cleaned out clogged toner supply tubes a few times on the MPC 2500-4500 range.
                        And I've also had a couple of faulty toner attraction pumps.
                        • spaceman99
                          • Jul 2009
                          • 174
                          NIGHTMARE FAULT .... Turned out the fault is caused by the toner signal from the NVRam not being altered when the new bottle installed.
                          FIX.. copy NVRam on to SD card. Print SMC report. Print of Non standard data report. Carry out MEMORY ALL CLEAR. Reinstall NON STANDARD settings,( mainly the Scanner settings) as you may have back ground. Time will tell if this has worked.
                          ( some machine just will not have it.) If this is the case turn of toner end detect in sp3 05 ???
                          • Fearless V K
                            • 620
                            I have had to do what Spaceman did also. Engine clear. Machine is f*&^%d afterward, and all settings, init's need to be reloaded and performed (line positioning, color cal., etc.)
                            • spaceman99
                              • Jul 2009
                              • 174
                              having done this loads of times now. it all works fine. NOTE: you must set up all non default data maualy re enterd. then set up the regisration rom sp ,
