aficio 850
  • tecnoacre
    • May 2009
    • 29
    aficio 850
    I'm friends with a problem on a Ricoh aficio 850, the copies are coming out white at the top of copies, already reviewed the laser, optical drive and not sucesso.imprimo got the meter and the part where you have the arrow is blank. I would like to help a
    tecnoacre
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 366
    tecnoacre
    Check the developer unit. You may have blockage under the doctor blade. There should be developer fully coating both upper and lower mag rollers. Use the mylar cleaning tool to clean the back of the blade described in your service and parts manual. DO NOT remove the white painted screws.
    You can rule out the optics since an internal counter page has the problem.
    Oh and also check your laser slit glass which sits above and slightly to the right of the drum unit.
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • tecnoacre
      • May 2009
      • 29
      aficio 850
      now replaces unit.developer for another and still the problem, already cleaned throughout the laser. already dismantled all the top to reach the laser and clean it inteiro.e still the problem persists get the look of more suggestions.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Is there a clutch which "cams in" the developer unit to contact the drum?
        If so, and if it is slipping, it will cause uneven pressure, which creates a gap, resulting in uneven prints.
        • copytechman
          • Nov 2008
          • 926
          Nope, no cam in mechanism, how bout the charger unit.. I know that usually the cleaner unit will cause black lines if not @ home but just worth a look regardless.. also is the xfer belt unit properly locked in? Both springs (iirc) under the belt in place? ..
          Food for thought!
          Regards!
          A.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Is it possible to stop a print midstream, and check to see if there is a good image on the drum?
            If there is, then it's a transfer problem, like you mentioned.
            • copytechman
              • Nov 2008
              • 926
              I agree try a sky shot and stop it half way to see what the image is like on the drum, probably easiest with 11x17 on that machine due to it's speed though!
              Regards!
              A.
              • tecnoacre
                • May 2009
                • 29
                aficio 850
                I will check and give it back, but I appreciate the tips
