What's wrong with the touch screens?
  • largo
    • 30
    in field we have to replace all touch screens of these models Aficio 3025/3030 DSm725/730 LD225/230Aficio MP 2510/3010 Aficio 3035/3045 DSm735/745 LD235/245Aficio MP 3500/4500Aficio 3224C/3232C DSc424/432 LD124c/132cHQ7000 CP6334HQ9000 CP6346DX4640PD DX4640PDAficio MPC 2000/2500/3000Aficio MPC 3500/4500Aficio MPW 2400Aficio MPW 3600Aficio MPC 2800/3300Aficio MPC 4000/5000Aficio MPW 5100Aficio MPW 7140
    anyone any explanation?
    greetzz
    greetz
  • unisys12
    • 489
    The TSB explained that there was a problem with the connector.
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
    • TonerMunkeh
      Professional Moron
      • 3865
      There's been a fault with touch screens on a few models. I've mainly seen them either way out of alignment or fail altogether. Mostly Adonis C4's too.
      Hit it.
      • Dave Ireland
        Many models of Ricoh touchscreens have a defect-Ricoh is sending out replacements,list of models,& instructions.
        • paulg
          • Jun 2007
          • 278
          Well on the Tessa tier 2 knowledge base
          it says the cause is
          The adhesive that binds electrodes to the touch panel surface contains a polymer that tends to expand under normal office environmental conditions.
          Lists a whole load of models with serial cut out with the possible defect.
          • AV8R
            Lurker
            • May 2008
            • 12
            It's amazing that they are all failing at the same time. I can't get the screens fast enough to keep up.
            • Vulkor
              • Jun 2009
              • 946
              We are lucky in Texas. Only had maybe 3-4 fail so far.
              • Froota
                Field service tech.
                • 129
                Here the same problem!
                most on af3224c....
                • Ralph S
                  We were shipped enough of these to cover our population and the techs are replacing them as they do regular service calls or if they fail before that of course. We got 6 boxes of them for the different models.
                  The sub manufacturer is probably taking it in the shorts for this issue.
                  • largo
                    • 30
                    do you know what I think?
                    It's like other products they taking back (cars, toys,...)
                    not because of a little mistake,....
                    but when they do this it's all because off safty reasons!!!!
                    why should we do all touch screens preventifly now and not the only ones who are realy defective (1/100)?
                    who agrees?
                    greetz
                      • 23008
                      Can't speak to Ricoh, but...
                      Kyocera has had a few batches of bad displays. The official explanation is that the conductive adhesive that adheres the ribbon cable to the face develops resistance/loses connection. It wouldn't surprise me if they used the same supplier of touch displays as Ricoh. =^..^=
                      • Lagonda
                        • Aug 2008
                        • 1649
                        I was having a moan about this back in December 08 and no body in the northen hemisphere seemed to have much of a problem with it. Its the end of winter here now and the field techs arn't going through as many as they were in summer. Perhaps its heat related?
                        • zyqwiz
                          • Jun 2009
                          • 333
                          We had a couple when it was hot the other month. Luckily an English summer only lasts a week.
                          • wings
                            • May 2008
                            • 12
                            Here in Holland we had a lot of 424's that stoped working or had wrong location of the fields, callibration helped for only one week.
                            • paulg
                              • Jun 2007
                              • 278
                              who agrees?
                              Annoying to have to do and of course can course a lot of problems if you go in for a paperjam and start fiddling with the op pannels many will be like
                              But as the replacments i belive for ricoh europe cost 1 cent at present and prevention is better than fighting fires in the majority of cases. Its probably for the best.
                              The problem in the UK did seem to go though the roof as other Brits mentioned in the "summer" all one week of it
                              So during the busy period for many copier companies ie after the summer break sept/oct if its fairly warm as sometimes happens or the heating is switched on automatically or to test for the winter as many workplaces do i have noticed causing one off freakish issues. I guess there will be another big wave of my touchscreen doesn't work calls.
