Aficio 1075 Scanner Setup
  • datapresstecnica
    • May 2008
    • 35
    I've been trying with no succes to setup a scanner in an Aficio 1075. I'm used to work with KM machines and this one is completely different. Can anyone tell me how can I setup scan to folder option or scanroute lite? I can't find any options in neither the web setup nor the machine's display. The machine is equiped with scanner option, but I can't get it to work.
    Thanks a lot
  • Vulkor
    • Jun 2009
    • 942
    Setup Guide for Scanrouter Lite. Scanrouter is a POS No longer supported by Ricoh/Savin. Hell I just googled it and you cannot even GET Scanrouter Lite on the Savin/Ricoh Scanrouter Pages anymore.
    • apache_cat
      I.T. Tech
      • Jul 2009
      • 81
      Scan to folder on Ricoh.
      Web in to Copier. Login in User Name admin there is no password. Then you will see the address book.
      Click Add user fill in name and key display ,go down to folder and fill in path, user name and password.
      If the shared folder is on the C: drive the path will be: computer name\shared folder name. If you have set a DNS.
      If no DNS the path can be : ip adress of computer\shared folder.
      Hope this helps
      • datapresstecnica
        • May 2008
        • 35
        Thanks a lot
        • KopyKat
          Nurse Ratched of Repair
          • Nov 2008
          • 366
          If the shared folder is on the C: drive the path will be: computer nameshared folder name. If you have set a DNS.
          If no DNS the path can be : ip adress of computershared folder.
          Hope this helps
          The 1075 does NOT scan SMB to folders...Twain or Scanrouter only!
          You may still be able to get SR Lite through this link:
          See this post:
          sigpic
          Relax! This firmware injection won't hurt...but it will take 45 minutes.
          • datapresstecnica
            • May 2008
            • 35
            Ok, no SMB available.
            The problem I have now with SR is that when I try to add the copier as a server (either by manually entering IP or by searching) it says that it can't find the server. The machine is already connected as a printer and it works fine, so it's not a connection issue.
            Is there any other setup I should check? Do I need to setup a workgroup? The machine is connected peer to peer with only one pc, no domain server or router between them
            • shopgirlslc
              • Aug 2009
              • 13
              Scan Router Lite V2
              In order for Scan Router to get a response, you have to unblock port 3670 in any/all firewalls running on the PC it is installed on. This includes Windows Firewall and any anti-virus that is running.
              Also - Check to make sure the Delivery Server is the IP Address of the PC the software is on. I have ran into a couple machines that have all zero's for the IP Address of the delivery server (Found in File Transfer). If this is the case, you can manually put it in in Service Mode 5845-001.
              • KopyKat
                • Nov 2008
                • 366
                Read this and the attached files...
                Open port 3670 tcp in the firewall on the computer and you must turn on the Delivery Server in User Tools/Admin/File Transfer
                Try using the search function on this site...it will get your questions answered faster.
                sigpic
                • KopyKat
                  • Nov 2008
                  • 366
                  Yes you can...secret link they never deleted it just deleted the link to it...
                  http://support.aficio.com/bb/pub_e/d...0/z02671L8.exe
                  sigpic
                  • apache_cat
                    I.T. Tech
                    • Jul 2009
                    • 81
                    See this post:
                    http://www.copytechnet.com/forums/ri...html#post63822
                    My mistake thanks for correcting KopyKat. Been a long time since I came across one that didn't smb scan.
                    • msaeger
                      • Sep 2008
                      • 333
                      The 1075 also supports scan to email which is much easier to setup and does not require a computer running scanrouter.
                      To set it up you just need to connect to the web interface and log in with no user name and "password" for the password. Then you just put the SMTP server in with authentication info if required. You have to setup the email addresses from the operation panel in system settings or if you are really afraid of the panel you can do it with smart device monitor for admin.
                      • Scott_Lewis
                        • Mar 2007
                        • 519
                        Never set up scanning on this model. But, isn't there an SP setting to enable delivery server. This required for SR?
                        • KopyKat
                          • Nov 2008
                          • 366
                          No, it's done like this: Turn on the Delivery Server in User Tools/Admin/File Transfer.
                          sigpic
                          • KopyKat
                            • Nov 2008
                            • 366
                            No problem apache_cat...I have trouble sometimes remembering which ones support SMB.
                            Unfortunately I have a few customers that refuse to let go of their old 1060/1075. Can't blame one particular customer...most of their 1060s have less than 500K on them.
                            sigpic
                            • Cobrafixer
                              Scanner
                              Thanks KopyKat!!! I was just able to get my scanner up and running, we have an Lanier LD 075 and I had to go through all this just to get it set up, there isnt a mailbox when I go to the web and log in. Then I had to go back through the links a few times to pick up that I had to unblock that port on the fire wall....2 and a half hours later all is good!
                              THANKS SO MUCH FOR THE POST!!!
