aficio 1224c
  • kittybo
    aficio 1224c
    1st copy fine but then smudges lead edge appros 1 inch in ..have changed bk dev and magnectic clutch for bk dev.....fuser been changed as have pcu....any ideas please
  • Eric1968
    • 2458
    I assume the firmware is up-to-date. Had this a few years ago. Solved the problem with a new transport assy (B051 4800). I believe there's also an RTB for this problem.
    • Jomama46
      • 2900
      Sounds like a cleaning issue. When you installed the new pcu did you make sure the new spacer is on the cam that raises and lowers the cleaning unit.
      I fixed one one time by beating the crap out of it with a 20 lb sledge hammer. No wait, that was a dream.
      sigpic
      A+; Network +; PDI+
      • kittybo
        lol..have you part number for sledge hammer!!!!
        • kittybo
          thanks for replie will try transport bed
          • Jomama46
            • 2900
            It wont be a bed until you smash it with the aforementioned hammer.
            Eric is talking about the Transport assy. A box of gears and clutches in the back that primarily raise and lower the cleaning unit. The new number is B051-4807.
            sigpic
            A+; Network +; PDI+
            • aabarnes1
              • Mar 2009
              • 620
              On A serious note, the fuser can leak silicon oil onto transfer and consequently clog up dev units. What mileage is on the machine and has the oil supply unit been replaced?
              Pno: for sledge hammer: B1ig Axxe
              Grant me the serenity to accept the things I cannot change.
              • kittybo
                machine only done approx 100k...havent changed oil supply will double check though11
                • aabarnes1
                  • Mar 2009
                  • 620
                  If I remember correctly, oil supply unit is 60k life. Anyway pads leak before life count is up, shite machines, sell them a new one
                  • Jomama46
                    • 2900
                    Roger that last transmission
                    sigpic
                    A+; Network +; PDI+
                    • Philinghorn
                      • Sep 2008
                      • 29
                      Hello,
                      If its any help we had the same fault today after replacing the pcu , new transport bracket sorted the fault.
                      All was fine with the old transport bracket before the new pcu was fitted.
                      • Vulkor
                        • Jun 2009
                        • 946
                        How does that surprise me. We've replaced the Transport Bracket on Some machines almost everytime we've replaced the PCU.
                        PIECE OF SHITES!! Grr
                        • CableGuy
                          Impulse Drive Engineer
                          • Oct 2008
                          • 417
                          If you do two A4 colour copies, does the second one look ok? I was having this problem, replaced to transport assy, job done.
                          • Brave Hart
                            • Aug 2009
                            • 73
                            Clean your cleaning unit clutch, it is binding causing the smudges.
                            What? HuH?
                            • claudioterrible
                              no mercy...
                              • Oct 2008
                              • 96
                              there are two springs clutches,AB040020,THEY BECOME "WEAK" and produce this kind of copies
