Hi everyone,
I have an MPC2500 that's doing the following : When you make a color copy, colored lines are visible in solid areas. For example, in a solid black area I see a thin green line, and in a blue area I see a thin yellow line.
The lines are not visible on the white areas of the paper. Updated scanner, engine, and system firmware and cleaned the optics, but no result. Black copies and all prints are OK.
Before I order a new lens assy, does anyone have an idea?
Thanks in advance
Thanks in advance
