2035e
  • hodgiepodgie
    • Jul 2008
    • 284
    2035e
    after documents are scanned customer tries to "e file" them to court house error message says wrong size paper.8.64 x 11.00. copier is fine latest driver happens only when e filing.must be somthing w/efile drivers.anyone have similar problems.
  • Shadow1
    • Sep 2008
    • 1642
    Is the machine set to english / inch units - sounds like its trying to send it as A4 size paper.
    73 DE W5SSJ
    • hodgiepodgie
      • Jul 2008
      • 284
      copier is not problem all is correct as far as copier.got to be e file have other machines and customers w/ problem similar
        • 23009
        I've read about similar situations. A lot will depend on the capabilities of the AF2035.
        The situation I was reading about was legal docs efiled to a courthouse from a Falcon II, Kyocera Mita KM-3035. This machine cannot specify the scanned original size. Now the Falcon III, KM-5050 you can select 11 x 8 1/2 letter and it will give you an 11.00 x 8.50 inch document exactly.
        At least on the Kyocera products we could not find a way to specify the original size for the Falcon II. It was not strictly based on the exact size of the original document (for example: all "letter" originals consistently scan at 11.03 x 8.61).
        On the Falcon III, when original size was left to Auto, "letter" originals consistently scanned at 11.04 x 8.64 inches.
        • nmfaxman
          • 1702
          Is auto size detect set as default in the scanner settings?
