Ricoh MP900/Toshiba 901...fuser Jam 21
  • tech07
    • Aug 2008
    • 410
    I ,m really reaching out for input here guys. Been fighting this for days. I get many Jam 21 jams that seem to occur in the fuser. The lead copy will be rolled up at the upper guide /pickoff area. The trail edge has cleared the heat roller but is curled up (wavy). There are no classic pickoff finger symptoms, such as nicks or accordian pages. Just rolled up, not coming out of the fuser. It doesn't make it to the exit/ heat pipe section..I can't even se the paper unless I open the upper guide with the pickoffs on it and there it is ..just sort of rolled up...jam 21... Oddly enough it will run several hundred pages ok the jam 21 for 20 pages in a row, then run ok again for 500+ copies.. Am I looking in the wrong place?? I replaced the entire, ENTIRE fuser unit 500K ago. Help...
  • tech07
    • Aug 2008
    • 410
    I believe this is an MP9000 not 900.. Has 14Million copies on it
    • Shadow1
      • Sep 2008
      • 1642
      Just fought this on a MP7500 - totally different machine, I know, but exact same symptom so maybe it'll help.
      It boiled down to to a dry web - they somehow missed putting any silicone oil at all in the web.
      73 DE W5SSJ
      • RG1964
        • Jul 2009
        • 56
        There was something wrong in the SMC report. Check the jam code list in the service manual. It had something to do with the duplex or registration instead of the fuser.
        • Kopyrtek
          Copier Psychologist
          • Jan 2007
          • 407
          Check the fuser drive.
          • slot
            • Jul 2008
            • 341
            there are some one way bearings in the fuser drive that played up on the old 1090 also check there is an even gape from front to rear between the black belts that run under the cooling bar and the black guide on the hot roller stripper unit they often get bent at the front edge so the paper path is a little tight. also try running the copier with all the spers removed these can cause jams also
            • Shadow1
              • Sep 2008
              • 1642
              Removing the spurs will eventually bite you, but they can cause problems if they get bound up with toner. They usually get little balls built up on the tips until they don't turn anymore - its not too hard to clean them up and make sure they rotate freely.
              73 DE W5SSJ
              • iMind
                Vacuum Cleaning Expert
                • Mar 2008
                • 1116
                I personaly would pull out the feed station 1 theres a bushing more like a bearing on the back of that feed station that supports the pick-up roller could be warn out, I had one that gave me the same jams: 9500K, so I would take a look, only takes Half an hour take out and put back in.
                • tcs04
                  FORMER Techie
                  • 1183
                  Check the fuser pressure. If the nip is high (about 13mm) reduce to about 9-10mm (Ricoh Tech Bulletin). Also check that it's even. If it varies at the edges, change the pressure roller and re-adjust. As mentioned, the "spurs" on the stripper fingers clog with toner and can cause the lead edge of the paper to fold back on one corner. If so, change the fingers. Try changing the guide at the lead edge of the exit unit, thee was a mod for the (older) AF1085 related to this part. Some of our techs suggest changing the sensors at the fuser exit (Long lever) and in the exit unit.
                  • Patish
                    • Aug 2008
                    • 66
                    From RICOH "knowledgebase" :
                    Sometimes a fusing unit jam occurs (Jam 21 paper does not reach heater pipe exit).
                    It is difficult to reproduce.
                    [Cause]
                    Fusing drive motor (AX060329) brushless motor drive is faulty.
                    [Resolution]
                    Replace the fusing drive motor (AX060329).
