af-1060 w-550 code
  • T911
    • Jun 2007
    • 628
    af-1060 w-550 code
    swapped web assly with another and reset code but will not go away. repl-web sensor and harness but no luck either. ideas appreciated. thanks t
  • Jomama46
    • 2900
    1902-1 should be reset to 0 and the rest should be left at their default.
    sigpic
    A+; Network +; PDI+
    • schooltech
      School District Tech
      • Jun 2008
      • 504
      Once you reset that code to 0, you will have to shut the machine off then back on for the machine to 'see' the change.
      Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
      • T911
        • Jun 2007
        • 628
        reset code guys, looking for something else here. thanks t
        • Shadow1
          • Sep 2008
          • 1642
          Some of the really early firmware had Web problems.
          73 DE W5SSJ
          • msaeger
            • Sep 2008
            • 333
            Try setting the 1902-1 to 1
            Is the web unit plugged in ?
            Maybe the sensor for web end on the web unit is not working either from a bad sensor or the actuator not being right.
            • schooltech
              • Jun 2008
              • 504
              Hmmm, if you've reset the counter back to 0, and power-cycled the machine, there must be a bent pin or bad sensor.
              I believe that the firmware made an adjustment in the timing so that the motor did not turn faster than the internal counters, causing a premature 550.
              Make sure that the sensor flag is completely out of the sensor. I've had some not move very well over time and the spring can cause some problems as well.
              • Shadow1
                • Sep 2008
                • 1642
                There were multiple symptoms - Some machines the motor would run more than it was supposed to (sometimes it would not stop and run out a web almost instantly) Sometimes the counter would not update properly and you would get a 550 with the web properly consumed, but only showing 15% on the counter, and sometimes the counter would not reset properly.
                I only mentioned this because its an odd problem, and odd problems have unlikely solutions - so its unlikely a machine with firmware that old is only now exhibiting symptoms, but as you know, given enough time anything with a non-zero probability of occurring will eventually rear its ugly head...
                73 DE W5SSJ
                • T911
                  • Jun 2007
                  • 628
                  tech bent pin in harness connector, thanks much guys
