Ricoh AP3800
  • bjmccreedy
    Ricoh AP3800
    I have a Ricoh AP3800 copier with error message SC552 (pressure roller warmup). I have replaced the fuser and get the same message! What can I do now? Thanks!
  • tr21x
    • Feb 2007
    • 26
    SWAP OUT BCU
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Update the firmware to the latest versions BEFORE you look to replacing the BICU PCB.
      Warm-up timing was changed to prevent SC552 mis-detection from engine B1.25 onwards.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        BTW there is an SC reset you need to execute in SP mode for fuser codes.
        Mystic Crystal Revelations
        • Zeldaman
          • Mar 2011
          • 946
          • KOPYTEK55
            • Nov 2009
            • 21
            I have seen many of these machines with paper in the connector , so many i bought a dental pick to get them out , and don't forget the SC reset .
