customer complained tha it jams in the doc feeder. paper is not feeding through sometimes to start off with.all the rollers are clean. ive tried turning the gears manually but not enough squeaking is producing.
the sqeaking noise i cant get rid of. did adf free run in section 6 and still cant tell where its coming from. also squeaks when doing double sided. has anyone else had the same fault??
it tends to squeak when it gets to the scanner slip glass and turns the paper around.
