MPC4500 fuser exit sensor Jam
  • neergish
    • 177
    Thought I might share a fix for a bit of a hair puller I had on a MP C4500.
    Originally got a call out to the machine because the ADF was jamming (blue-tac in the paper path, not related but always good fun) while taking down my usual readings I noticed there were a lot of paper jams at the fuser exit sensor. Thought it may have been a bad fuser but i had only rebuilt it a week before.
    Chucked a few copies at the machine and I got an intermittent jam, paper was stopping just below the fuser every now and then. I swapped in a new exit sensor, still getting the jam.
    Hope this helps someone.
    (naturally now that I have posted this I expect the machine to start jamming again)
    "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
  • mabawser
    Tech
    • Sep 2009
    • 121
    Mpc4500 jams
    Had a very similar fault on a mpc3500 but it was the transfer roller causing the paper to buckle before the fuser entry intermittently.
    In fairness the roller was over life but they do run way over life.
    Just thought I'd mention it if you need to go back?!.
    cheers
    • Fearless V K
      • 620
      Had one just last week that moving the fuser entrance guide fixed also.
      Don't take that toner with me!
      • kayjaig
        • 144
        try the enter sensor
        try to replace the enter sensor, the one is located right above the transfer unit. good luck.
