Ricoh 1232c printing issues
  • smackloaf
    • Jun 2025
    hi
    i know this printer has a bad rep: please help though if you know
    i would have bought a different machine but i was naive
    im using indesign cs3
    and when i print out an this book im doing on an a3 piece of paper it is half off the page, iv tried EVERYTHING (obviously not everything because it would obviously be fixed) but to my knowledge anyway.
    opened up other files etc.. does the same thing
    it never used to do this but i cant think of what has happend to make the alignment go off centre ?!
    any ideas
    thankyou
  • Jomama46
    • 2900
    Maybe the side guides in the cassette are broken and the paper is therefore off center. Try using the bypass to feed the paper. If it works OK in the bypass then the cassette is at fault. If it fails in the bypass, it is either a setting in the program or the firmware in the machine needs a touch.
    When you make a copy, is the image off center too? If so, see above. If not, the problem is in the program, i.e. wrong selection.
    sigpic
    A+; Network +; PDI+
    • smackloaf
      hi , thanks for the reply
      when i copy, it prints out fine all aligned properly
      i have been fiddling around with the settings but i really really dont know what to do!
      • Jomama46
        • 2900
        Its not a 1232 issue then. Maybe the program is set to print in landscape instead of portrait? or Visa-versa?
        sigpic
        A+; Network +; PDI+
        • smackloaf
          alas, believe me its not that simple
          its defiantly something to do with the communication between the printer and the software il show you an image:
          The safest and most inclusive global community of photography enthusiasts. The best place for inspiration, connection, and sharing!
          if you look on my flickr page i have notes showing whats happening...
          • Jomama46
            • 2900
            Oops! You don't have permission to view this page.
            But at anyrate, I dont have any other ideas
            sigpic
            A+; Network +; PDI+
            • copytechman
              • Nov 2008
              • 929
              This is gonna sound kinda dumb but does a windows test page print correctly? (proper orientation etc?)
              Regards!
              A.
              • smackloaf
                hi
                im on intel mac
                i havent tried printing from a pdf yet im going to do that tomorrow
                ..any other suggestions meanwhile would be greatly appreciated
                thanks!
                • Shadow1
                  • Sep 2008
                  • 1642
                  PageMaker and InDesign are notorious for formatting problems like this, just as MS Publisher absolutely never gets the fonts right on a different computer.
                  Have you ever tried Scribus scribus.net | Scribus Open Source Desktop Publishing It's open source, so it's completely free. It's also completely cross platform (Windows, Mac, and Linux)
                  Try printing your doc through Scribus (you'll have to export your InDesign to a .PS file, then Import and check your document before you export it to a PDF and print.) If it doesn't print correctly from here it never will, and its a machine or driver problem
                  Scribus' only mission in life is to be a stellar Desktop Publishing application - it does not print directly, but outputs a very high quality .PDF file which can be printed locally or sent to any print shop without a problem (remember to embed the fonts) I've done several projects with it - it's easy to learn and use, has a great support community, and it absolutely free. I've also had absolutely no problems creating a document on my Linux home computer, editing it on the Windows XP box at the charity I work with, and tweaking it again on an OS 10.4 mac at the print shop running it for me.
                  73 DE W5SSJ
                  • smackloaf
                    thanks from pdf works fine!
                    its something todo with indesign most certainly..
                    now it says the paper trays
                    internal tray
                    standard tray
                    are both full.. when there is no paper inside the machine AT ALL?!
                    hmmm any ideas people im so sorry.. im happy zero experiences with ANY machines like these.. its crazy
                    only lazer and inkjet printers.. .. these machines seem to talk in riddles
                    • Shadow1
                      • Sep 2008
                      • 1642
                      Unfortunately, I don't have nearly as much experience with Mac as I'd like. All I can say for something like that is to get the latest PPD's for the printer, and make sure all the other software has been updated.
                      Or just stick with using Scribus - it'll save you a lot of money in the long run.
                      73 DE W5SSJ
                      • smackloaf
                        no probs.. now i cant even bloody print anything now anyway... maybe i should TRY to sell urhghh...
                        that error internal tray is full .. keeps coming up and theres nothing there..
                        as for the software.. im a graphic designer...so .. i NEED to use indesign unfortunately
                        no choice in the matter got the latestly ppd etc.. so.. yeh.. really really irritating.i hate spending time on technology
                        • Shadow1
                          • Sep 2008
                          • 1642
                          Internal tray full is usually a sensor just above the exit on the internal tray. There is a lever that folds out of the machine to detect the paper stack height - if it gets folded back into the machine it thinks the tray is always full.
                          73 DE W5SSJ
                          • smackloaf
                            the EXIT on the INTERNAL tray?
                            just to let you know i have NO manual at all...
                            there is a black lever where the print comes out.. and a black lever INSIDE the machine hovering just above the paper...
                            which one do you mean...
                            im so fucked
                            • Shadow1
                              • Sep 2008
                              • 1642
                              The lever that causes this is just above where the paper comes out inside the machine. It's black plastic about and inch and a half (5cm??) long. When its folded out it hangs down so that when the paper stacks up in the exit tray about 500 sheets will hold it up. When it is folded back into the machine, its almost invisible if you don't know its there - it just looks like a black bar above the gap where the paper comes from. If its folded in, you should be able to grab it with your fingers and GENTLY pull it out - it hinges in the front - be careful not to snap it off.
                              If somebody already snapped it off - good luck. It takes a bit of skill with a screwdriver to get access to replace it. Fortunately they don't break all that often - they usually just fold back in.
                              73 DE W5SSJ
