What would cause what appears to be poor transfer in a Ricoh 400 copier when copying large runs and intermittently the lead side will start out what appears blank and then the rest of the copy is fine or the copy will come out fine then go almost blank. Customer says they can see a latent image where it comes out blank. The tray being used is the top drawer set up as 8.5x11R. I'm thinking the registration switch. The copier doesnot error out when the faint copying occurs. Please help!!!!
Thanks!!!!
Thanks!!!!
