mpc2500
  • digicor
    • Jul 2008
    • 1159
    mpc2500
    I have a mpc 2500 running poor black copies, almost like the dv is shot but not all the way across the page, the bottom of the counter sheet is perfect, but as it goes up its faded to the point of no print. I have replace the whole entire blk IU with one from a perfectly good running machine and the same problem, it also will not calibrate itself.
    any ideas on this??
  • serpico
    • 14
    Hello,
    Try to move the laser shutter or remove it.
    Update the firmware to solve this problem.
    • mabawser
      Tech
      • Sep 2009
      • 121
      if the laser shutter is not jammed as mentioned previously, replace the laser unit.
      Had this fault just before xmas. cleaned all the laser unit mirrors, replaced blk dev,drum no joy!!!
      Replaced the whole laser unit B238-1854
      hope this helps
      • mabawser
        Tech
        • Sep 2009
        • 121
        hope this helps
        just a thought, that part number is the EU one
        • Eric1968
          • 2458
          I've had a lose transfer roller bushing on one side of the transfer roller assy. Had the same result as you described. Dirt on the laser shielding glass could also be the problem.
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            Have had 3 machines and firmware corrected problem for me. Engine must be at least 1.13 I think
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • digicor
              • Jul 2008
              • 1159
              thanks dudes
              ill check the firm ware in the am
              and the laser shutter and all!! LOL
