please wait upper left of screen. repl-2 new hdd's reformatted and stamped them but no luck. i can make a copy and quickly make another copy and another if i am fast enough, but when i wait 3 seconds it goes into a please wait and will not come out. i can turn the machine off/on then it will come to ready again, but iif i make a copy and wait 3 seconds it will do it again. not the initial please wait but the one in the upper left where the screen says ready. help appreciated. thanks t
af2075
You may have already done this, but it sure sounds like a firmware problem. Also, I had a 2051 that I adjusted the metal plate on the front of the machine that secures the fuser in place. I had moved it about 2 mm too far to the left and got the same "please wait" indication. Hope this helpsNEVER ASSUME ANYTHING
