af2075
  • T911
    • Jun 2007
    • 628
    af2075
    please wait upper left of screen. repl-2 new hdd's reformatted and stamped them but no luck. i can make a copy and quickly make another copy and another if i am fast enough, but when i wait 3 seconds it goes into a please wait and will not come out. i can turn the machine off/on then it will come to ready again, but iif i make a copy and wait 3 seconds it will do it again. not the initial please wait but the one in the upper left where the screen says ready. help appreciated. thanks t
  • mikadonovan
    • May 2008
    • 2931
    You may have already done this, but it sure sounds like a firmware problem. Also, I had a 2051 that I adjusted the metal plate on the front of the machine that secures the fuser in place. I had moved it about 2 mm too far to the left and got the same "please wait" indication. Hope this helps
    NEVER ASSUME ANYTHING
    • brij
      • 11
      how old is the developer. try new developer. it might be from td sensor.
      • T911
        • Jun 2007
        • 628
        it was the fuser guys. replaced all the lamps, stats and stors, thanks much T
