Ricoh printing issue
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Ricoh desktop printer can not handle job of more than a few pages. After that the machine starts leaving out parts of the document and then gives a low fuser temp error. Anyone had a similar problem?
  • Fearless V K
    • 620
    I can't handle working more than a few days in a row. After that I start leaving out parts and get a headache plus fever (brain overtemp error?) Is that a similar problem?
    Sorry, been a long day.
    Don't take that toner with me!
    • landspeeder
      • Feb 2010
      • 355
      see if they are using a postscript driver if so change it to a pcl...should fix the problem...maybe...oh didnt see the fuser temp thing....hmmm...try the driver...makes it look like something is being done
      You never realize how cheap a professional is until after you let an amateur do it.... and
      if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        I brought it back to the shop to test. With pcl drivers it prints as many as 50 pages then does its little trick. When you cycle power it starts printing on its own, but does not pick up where it left off, it starts over and then gets to the same number within a few pages and does it again. I called tech support and they said it could be this or it could be that or maybe this. I pretty much had it narrowed nown to something in the machine. I will start by changing the fuser.
        • landspeeder
          • Feb 2010
          • 355
          pieces of print
          If the press roller is warped or not pressing right..maybe worn bushings...the paper does get pushed hard enough against the heat roller and can cause a problem..also a weak heater can cause the low temp and for toner to fall off the paper...works over ..have a great weekend!
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            Ricoh sent me a 220 volt fuser. This made me start a new thread about bad tech support.
            • Herrmann
              • Jan 2006
              • 792
              lets go to the start, from what model you are talking?
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                • 23008
                How much DIMM memory does it have? Upgrading the memory might help (at least with the print issue...). =^..^=
                • fixthecopier
                  ALIEN OVERLORD
                  • 4713
                  Well at this point I am trying to get the correct fuser without paying for the wrong one. This is what caused me to start my thread on tech support.
