Mpc 4500 tray 1 jams
  • Wishbone
    • 100
    This one has me stumped. Paper does not leave the paper tray and it jams every time. Tray 2 works perfect. I updated firmware and swapped trays 1 and 2 paper feed units. Still jamed on tray 1. So I swapped trays 1 and 2 paper feed clutch and tray 1 still jams. Don't know where to go next???
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    whats the jam log saying
    Incontinentia Buttocks
    • daveyball
      • May 2009
      • 314
      I've had exactly the same, I was going to swap out thr I/O Board, and I was unplugging all the connectors, and I thought what the heck, and plugged them all back in, and guess what it worked, must have been a poor connection. The fault you are having sounds exactly the same. The fault i had was not even picking the paper up and showing jam, only from tray 1. Try it.
      • action
        • Feb 2010
        • 3
        I had a similar issue. Apply pressure to the rh cover and see if it changes anything. If it does beef up the door latch pin on the frame of the machine. I have successfully done this with some electrical tape. In my case the machine thought there was a jam even though no paper was being fed from tray 1 from machine vibration. you will notice there is alot of slop on the door catch.
        • Vulkor
          • Jun 2009
          • 946
          Not surprising, These machines wire harness's get thinner and thinner with each generation.
          • Wishbone
            • 100
            I went ahead and ordered a new board just in case. I will try re=seating connectors first and will also check the door latch. Btw, it is logging all jams at jam code 3.
            • spaceman99
              • Jul 2009
              • 174
              I had a similar error. I swapped out the complete feed assembly and have never been back. I had already done cultch motor etc.
              • genius_at_work
                • Jul 2008
                • 7
                It may sound dumb, but check that the feed roller for that tray is in correctly. I had a jr tech install the feed roller backwards before. The 1-way bearing on the feed roller should be towards the front of the machine when you install it on the shaft. If it is installed backwards, it will not feed the paper from the tray.
                • knightfall
                  • Jul 2006
                  • 633
                  I would check that the paper feed roller is sitting in position and the plastic stay that holds the pf roller is also properly in place and inspect for wearing, I would also check the pf clutch it may be slipping. good luck.
                  Get your facts first, and then you can distort them as much as you please.
                  • msaeger
                    • Sep 2008
                    • 333
                    Did you try the output check for the paper feed clutch on tray 1 ?
                    • Wishbone
                      • 100
                      Update :
                      The Bcu fixed the problem. The paper feed clutch wasn't getting the signal to turn on.
                      • spaceman99
                        • Jul 2009
                        • 174
                        Excellent......................
                        Nice to see a fix on the forum.
                        Many questions but hardly any closure, so will never know what it was.
                        THANK YOU
                        • Vulkor
                          • Jun 2009
                          • 946
                          How very odd. Was the BCU and not the Harness? Hate the unreliable boards Ricoh has been putting in machines lately.
                          • atdejong
                            • 7
                            Same Issue Here...
                            I am having exactly the same problem, tray one jams (but does manage to feed out a few cm), and tray two works fine. Swapped clutches, feed units, trays, problem stays on the first tray. Im heading out right now to reseat the connectors, (thanks for the tip!) hopefully it doesnt need a board.
                            Thanks for the tip folks!
