MPC 2500 - B&W and Color
  • phabran
    • Nov 2009
    • 32
    Just cutting the edge didn't work. We compared and tested both cyan and yellow connectors and the pins order doesn't matches. Changing the pins order and it's done! Working fine!
    • spaceman99
      • Jul 2009
      • 174
      HI
      Dikes post kills me man, GREAT .............. any ways try this link it may be usefull as i think the drums are made the same way. hope it helps
      http://www.copytechnet.com/forums/ri...40-5000-a.html
      • knightfall
        • Jul 2006
        • 633
        I think your referring to the next generation of models up the mpc2500/3000/3500/4500 all have same pin configuration, the next generation of models mpc2800/3300 has the last 2 pins switched.
        Get your facts first, and then you can distort them as much as you please.
        • Fearless V K
          • 620
          #19
          Or maybe Europe has swapped pins on the 2500's?
          Don't take that toner with me!
          • CableGuy
            Impulse Drive Engineer
            • 417
            #20
            What part number ( drum Unit ) did you use, just out of interest? The pins don't need to be swapped here in the UK, which I guess is the same for the rest of Europe.
            • phabran
              • Nov 2009
              • 32
              #21
              In deed, the test we did was on a MPC2800. Perhaps 2500 is the same. I will confirm tomorrow.
              • Fearless V K
                • 620
                #22
                no need to swap pins on the 2500.
                • FrankieB
                  • 12
                  #23
                  this is to funny i love it, the dyke thing that is, but this info is very useful, I thought that there was no difference except about 275.00 dollars, and the connector.
