MPC2050 magenta lines
  • Funkmaster
    • Aug 2025
    Hi Folks, I'm getting what looks like multiple magenta lines going from leading to trailing edge. These lines look like they are created by the laser. This happens while copying or printing. The copies look like a perfectly ruled page. I replaced the laser unit but it didn't cure the problem.
    Any ideas would be appreciated
  • spaceman99
    • Jul 2009
    • 174
    Have you tried running it in Single colour or test pattern from Sp.
    • anothertech
      • 1771
      Have you ruled out the M drum and charge roller yet?
      • TonerMunkeh
        Professional Moron
        • 3865
        That'd be my guess too, or the dev unit seals are shot. I doubt the laser would cause this kind of problem, unless the IPU board's packed up.
        Hit it.
        • Funkmaster
          Not yet. Heading back in tomorrow
          • Funkmaster
            I tried a new M drum unit but didnt fix the problem. The lines are perfectly spaced all across the page almost like a test pattern. The lines are been written to the drum as opposed to bad charge roller or bad blade etc.
            • theom
              • Oct 2008
              • 14
              try too update the firmware
              • Funkmaster
                Will do the firmware tomorrow. Thanks. I will let you know how it goes.
                • mrwho
                  Major Asshole!
                  • 4299
                  I'd also suggest you post a scan of the image. You know what they say about an image speaking more than a thousand words, right?
                  Mascan42
                  Ibid
                  • Funkmaster
                    Thanks Mrwho, I will scan one in tomorrow.
                    • PA5RR
                      • Aug 2009
                      • 62
                      Obviously Funkmaster crashed onto a tree ?
                      I am curious about the scan ! I service this model for a year now and never encountered this problem..
                      technicians are the only ones that don't trust technical stuff !
                      • Funkmaster
                        Hi guys, I'm still in one piece. I changed the complete controller unit and it sorted the lines.
                        • PA5RR
                          • Aug 2009
                          • 62
                          Thanks for the info and glad that your still very heathy !
