Ricoh 2045 error code 395
  • satogoya
    • Jul 2025
    hey guys, im new in ricoh products and happened to run into a sc 305 error code could anyone please tell me how may I resolve it or deal with it
    thanks
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    305 is not listed in my book, but 304 is a charge roller error.check the drum unit. If it's 395 that's a development bias error, check and reset the developer. Power off/on to clear both.
    Mystic Crystal Revelations
    • satogoya
      yeah thanks for pointin it out i meant 395 and thanks for the answer.
      • JustManuals
        • Jan 2006
        • 9838
        I've got a file of Ricoh Error Codes posted on one of my sites at:
        Manuals 4 You - Free Feel free to buy something while you're there. (Baby needs a new pair of shoes)
        Paul@justmanuals.com
        • Tonerbomb
          • Feb 2005
          • 2589
          Your relentless ! The sign of a true salesman, weather it's copier manuals or used copiers.
          • satogoya
            well today went to the customer and the 395 code was there and after trying to reset de developer was still there and after a while code 402 came up and threw me off balance even more, i even put a new developer unit in the copier
            • Cipher
              It's not easy being green
              • May 2006
              • 1309
              SC402 could be directly related to the SC395 problem as both may occur if the high voltage board is faulty.
              • Paper_Jam
                Expecting a call.
                • Jun 2007
                • 101
                Did you notice alot of toner inside the front cover? Those machines had problems with getting toner into the door switches that are just above the fuser. There was a bulletin on that I think but I'm not able to find it right now.
                • satogoya
                  actually now that i think of it there was..
                  • Tonerbomb
                    • Feb 2005
                    • 2589
                    Props to Paper Jam! there was an issue with the switches and the wireing harness to them, chaffing. You should check them and the harness. Then check your transfer unit and the clutch for the transfer unit.
                    • ganc67
                      • Jun 2007
                      • 18
                      These codes are all related
                      you will need to completely change all components related to copy quality. dev. drum. transfer. main charge and make sure you do the td and id sensor adjustments after. And please do not use any after market parts
                      • satogoya
                        dont worry i dont work in that sh!t anymore I quit
                        • ganc67
                          • Jun 2007
                          • 18
                          you still on yahoo?
