SD Cards, size, formatting, etc.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Has anyone successfully used the Ricoh(Panasonic) SD card formatter on any cards larger than 1G? I can get the cards to format and load the romdata folder and the machine sub folders, but when attempting to update the firmware in the machines they all seem to kick SC819 codes. Same thing happens if I try to backup the address book in user tools. I'm assuming the Ricoh hardware can't read the cards over 1G, so is there anyway to partition or format the larger SD cards to be used? Anyone got tricks to use the larger capacity cards?
  • tcs04
    FORMER Techie
    • 1183
    I've noticed the same...... all answers welcome!!
    • Moza
      • 232
      As far as I know most (not all) models will only accept a maximum of 1GB
      • df3036
        • 109
        Don't think the Ricoh's can use SDHC cards. As far as I know they can see 2gig and below. Everything 4 and above is SDHC.
        Secure Digital - Wikipedia, the free encyclopedia
        Kittens give Morbo gas.
        A+, Network+, Server+, PDI+
        • zed255
          How'd ya manage that?
          • 1024
          Yes, my understanding is no SDHC's and 2G is supposed to be supported.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            IMHO, it's just not worth tangling with the larger cards to try to make them work. It seems that some brands fare better than others. Quite frankly, it's just not worth the time.
            I just go to tigerdirect.com (or similar) and order a dozen or so 1 GB cards whenever we need them. I can usually get them for just a couple dollars each.
