connect ing the one computer to the other computer in the office network
  • david ahn
    • 13
    When i try to set up the scan to folder(SMB) for ricoh multifunctional copier machine,
    i suceeded to set up in the one computer and failed in the other computer.
    In that case, i intend to convert the successful computer into the public computer, so
    from the other computer i can get into shared folder.
    For that, i need to make computer of shared folder open to other computers.
    I want to know how to do that.
    Thank you for your answer in advance.
  • ccchuah
    • Mar 2009
    • 157
    make a scan folder, right click the folder, click on sharing, following the instruction, let window do the sharing. When finish, you will notice the folder with a hand sign. Make sure all computer are on the same group.
    • Black Cloud
      • 164
      In microsoft windows click the Start key, then Help and Support. In the Search Help bar type "file sharing". There you will find step by step how to do it.
      Net+ PDI+ @Remote
