This puppy is marking the back of the copy paper with a grey line about 1/2" wide that spans the entire length of the lead edge (front to rear). The front of the copies looks good. If you've come across this please advice. Thanks.
Ricoh Aficio 2020D
Its overtoned. You can try detoning but I would just replace the developer and reset the AT. The transfer roller is probably ready for replacement too. As this is where the dirt is coming from.sigpic
A+; Network +; PDI+Comment
2020d back page ground
Hi Check your smc to see how many copies are on the developer if over 60k time to change
you could also turn on the transfer roller cleaning ( 2 996 1) and also the transfer current adj
(2 301 4 ) hope this helpsComment
