Ricoh aficio 2238c "fuser oil low" message ?
  • SOCPWB
    Hi, everyone: We got a " Fuser oil low " message from Ricoh Aficio. Dose that means we need to change new one or can any methods we can ignore the message keep printing?
    thanks in advance!!
  • tinfox
    • 317
    You can reset the code and keep printing, but I wouldn't do it. While there probably is enough fuser oil left in the container for a few prints, there will be NO warning when it's empty. If it dries up you'll be buying a new fuser as well.
    When you put the NEW fuser oil container in the code will reset itself.
    • cbrady
      • 10
      do not run it without replacing the oil,
      it will tear the fuser up
      • zyqwiz
        • Jun 2009
        • 333
        When it says 'low' buy a new oil unit then replace it when the machine stops and says 'replace'
        • Ricoh Dicoh
          • Dec 2010
          • 62
          Re: Ricoh aficio 2238c "fuser oil low" message ?
          I have fuser oil ordered for tomorrow but a customer needs it today. Will there be enough oil left in the bottle if i reset the counter to last them until tomorrw? What is the code?
          • xordi69
            • Jun 2010
            • 200
            fet
