IPDS 4100N
  • oswaldo160
    • Oct 2008
    • 69
    IPDS 4100N
    Hi everyone,
    Please help me, My costumer have the AS400 system and them need print.
    I have the AP 4100N and I don't know how is the process to add the IPDS here.
    I have the SD card and the information about Ipds.
    The information is a file: IPDS_E10_30_067_G176_G177.zip
  • oswaldo160
    • Oct 2008
    • 69
    Also I don't know what is the important in the IBM???????
    • Vulkor
      • Jun 2009
      • 946
      Last time we had a customer that used AS400 the Savin/Ricoh Software Division took care of almost everything between the Customer IT Dept and Ricoh customizing the files.
      • oswaldo160
        • Oct 2008
        • 69
        And did you use the IPDS???
        • Vulkor
          • Jun 2009
          • 946
          Uknown Oswaldo. Ricoh literally took the setup off our hands. I've nothing to do with their connectivity.
          • oswaldo160
            • Oct 2008
            • 69
              • 22999
              I don't know if this will help you, since I have only talked about this AS400 setup, but on Kyocera products the manufacturer recommends using an I-O Corp 5435-e IPDS print server, to the parallel port on the printer. This little box goes for $800 all by itself, without the required setup. =^..^=
              • zed255
                How'd ya manage that?
                • 1024
                I've always left AS400 set-ups to the company's admin, and there have been a few. No issues or special print server devices seem to be required. Guess that's why most places that use an AS400 system keep someone to administer the system around, or at least they should...
                • oswaldo160
                  • Oct 2008
                  • 69
                  I need the IPDS because will use the AP4100 with second tray
                  • 10871087
                    • Jan 2005
                    • 1143
                    I have used I-O Corps IPDS print servers many times in the past, they work great and they have always been very helpful with the setup and tech support.
                    PS. Blackcat, don't go through Kyocera for the box, you can buy direct from I-O and save a few hundred bucks.
