MP4000 jitter
  • mrwho
    Major Asshole!
    • 4299
    [CQ] MP4000 jitter
    Good morning, guys and girls.
    I've got a customer with an MP4000 which, generally speaking, runs very well (despite the horror stories I've been reading here in the forum - maybe I've been lucky so far).
    The only thing that I can't find a cause for it is that, once in a while, the machine will spit out jittered copies.
    The first time it happened, I blamed the fact that the machine was not plugged in to a grounded outlet - proceeding to correct this. This was a couple of months ago.
    Yesterday the machine did it again - and I can't find what could be causing this. The firmware is up-to-date and everytime I get to the customer, the machine's fine again - being the only proof the sheets of paper the customer shows me, since I'm unable to replicate this.
    The odd thing - and what makes me believe this is an electrical problem rather than a mechanical one - is that the jitter not only affects just the horizontal lines (the vertical lines are fine) but it also makes a repeated pattern throughout the lines - I was just able to notice this because the customer handed me a copy with a table on it, where the lines are perfectly defined - as you can see in the attachments.
    As a side note, and I don't know if this could be related - since the time reported doesn't mach the occurence - the machine reports a SC991 (on the scs_timer.c file) every morning around 9am (roughly the time at which the customer turns it on).
    Anyone ever had one of these?
    Mascan42
    Ibid
  • TonerMunkeh
    Professional Moron
    • 3865
    That's a bit of an odd one. With it being itermittent it may be the HDD and / or memory. Does the customer shut the machine down correctly before switching off? Try formatting the HDD, reaseating the DIMM's etc.
    Hit it.
    • mrwho
      Major Asshole!
      • 4299
      I'm assuming she does, but next time I get there, I'll ask her to do the shutdown procedure while I watch in order to verify this.
      Before leaving, I formated the HDD and asked the customer to power cycle the machine if the problem repeats itself, in order to find out if it solves the problem, even if just temporarily.
      Thanks for your reply.
      Mascan42
      Ibid
      • rthonpm
        • Aug 2007
        • 2853
        Try swapping the memory DIMMs with another machine and see if the problem moves. I had an MP C2500 doing something similar. It turned out to be bad memory.
        • Vulkor
          • Jun 2009
          • 946
          seen similar have had it be bad memory as well. HD is possible, but usually you get an SC code for that. I see you are getting 991, sometimes HD code, usually firmware.
          • Dusty
            • 17
            I had one doing exactly that with copies - prints were fine. I reseated the connectors on the board the ccd is on and cured it.
            • mrwho
              Major Asshole!
              • 4299
              Was browsing the forums and noticed I never gave feedback on this issue. So here it goes: after the HD formatting, the customer never called again with that particular problem.
              Cheers!
              Mascan42
              Ibid
