SPC410DN - SC241 re-occured after a long period of time
  • E Winter
    [Error Code] SPC410DN - SC241 re-occured after a long period of time
    Hi there,
    Anno 11/2008 we had a SPC410 with SC241 (faulty Y-LDB). Back then we swapped the LDB and the same error occured a month later wich lead my collegue to swap the engine board as well (the machine had warranty back than^^).
    Well now, after ~1,5 years, the same error is back and I can't imagine that the same parts went bad again. I also can't imagine that these parts where the initial problem. I think there might be a faulty polygon motor or sync detector board or a harness but on the other hand these parts should lead to other SC codes and/or disorted images wich isn't the case.
    Anyone had a experience with this sc?
  • Iommanxman
    • Aug 2009
    • 180
    Have you tried upgrading the firmware to the latest level?
    • E Winter
      According to the rep-history the last FW update has been performed early 2009 - haven't checked the change log tbh.
      • Iommanxman
        • Aug 2009
        • 180
        I have had weird faults like this before. Firmware flash or upgrade cures it. Other than that looks like your looking at a new laser unit unfortunately.
        • E Winter
          Yeah but after checking the prices for the laser parts I suppose that this is going to be a total loss for the customer who hasn't a service contract for the machine. Like for the example just the polygon mot + pwp is >400€ exl. VAT.
          • Iommanxman
            • Aug 2009
            • 180
            Yeah I can imagine it won't be cheap. This is situations where the customer can benefit from a maintenance contract and we (the dealers) loose out. The part number I can find for the complete Laser Unit is (G159 1850 - Laser Assembly).
