300gsm fusing
  • aspen
    300gsm fusing
    Hi
    I am having some client complaints that 300gsm is peeling/not fusing properly on a Ricoh PRO C 900.All recommended adjustments have been made ie:temp and nip width. Is there any other "secret" adjustments one can make to get better performance with the 300gsm.
    Regards
  • TonerMunkeh
    Professional Moron
    • 3865
    On what sort of machine?
    Hit it.
    • aspen
      oops...just edited post.Is on a PRO c 900
      • TonerMunkeh
        Professional Moron
        • 3865
        I doubt there is a way. 300gsm is 80gsm above the maximum spec for this machine. Maybe someone has played with this and gotten it to work?
        Hit it.
        • teebee1234
          • 1670
          Product planning guide states that Thick 3 is for weights of 221-300gsm. There are additional settings for coated paper. What are the paper specs specifically (Brand name, type).
          *Note- Tray 1 & 2 only support up to 220gsm, trays 3-6 will support up to 300gsm.
          Here is a list of paper/media that has been tested for quality and performance (Ricoh's words). Note that #19 is rated A+, it has a weight of 297gsm. Also note the disclaimer on the last page.
          • zyqwiz
            • Jun 2009
            • 333
            The spec is tray 1&2 60-220, tray 3&4 60-300, duplex is 60-220. Are they actually setting it to 'thick 3'
            • aspen
              Yes,machine set to Thick 3, special 3.Even tried Thick 3 coated 2 and 3. Temp has been changed to 205. Seems like when they have more dense images then the issue arises.
              Any news on the 'NEW COLOR PRODUCTION' machine Ricoh is releasing later in the year?
