Ricoh 1075 screen blank
  • msmy
    • May 2010
    • 123
    Dear All, Somebody please help me! I have ricoh aficio 1075 and having a problem with it. When I turn on the machine, the screen totally blank and suddenly comes with error code (don't know coz the screen blank!), signal for door open lights up (but it's totally closed!). Any suggestion?
  • TonerMunkeh
    Professional Moron
    • 3868
    Yeah, call a technician. Sounds like some fuses have popped in the PSU.
    Hit it.
    • mikadonovan
      • May 2008
      • 2935
      There's an adjustment wheel to the left of the display to adjust the lcd contrast. I know, it can't be that simple.
      NEVER ASSUME ANYTHING
      • teebee1234
        • Jul 2008
        • 1670
        BLOWN FUSE CONDITIONS
        Fuse Rating
        115 V 210~230V
        Symptom at Power On
        FU1 2A/125V 6.3A/250V Anti-condensation heater does not operate.
        FU101 12A/125V 6.3A/250V No response.
        FU103 6.3A/125V 6.3A/250V SC510 is displayed.
        FU104 6.3A/125V 6.3A/250V Nothing displayed on LCD.
        FU105 6.3A/125V 6.3A/250V “Door Open” is displayed.
        FU106 6.3A/125V 6.3A/250V ADF does not operate.
        FU107 6.3A/125V 6.3A/250V SC121 is displayed.
        FU108 6.3A/125V 6.3A/250V Finisher does not work.
        FU109 6.3A/125V 6.3A/250V “Door Open” is displayed.
        FU110 6.3A/125V 6.3A/250V SC510 is displayed.
        FU111 6.3A/125V 6.3A/250V Nothing is displayed on LCD.
        As TonerMunkeh says, call a technician. The fuse opened for a reason, replacing it won't fix the problem.
        • tcs04
          FORMER Techie
          • 1183
          Switch the machine off, pull out BOTH sides of tray 1, switch on. if the screen returns its the loom on the underside of the right hand tray rubbing on the tray runners and shorting the 24v line to the panel.
          • msmy
            • May 2010
            • 123
            Thanks guys. I checked everything as suggested, but everything are in a good conditions. Is it possible because of control units?
