RICOH -551
  • T911
    • Jun 2007
    • 628
    RICOH -551
    345 CODE (BIAS LEAK) CHANGED DEVELOPER AND CALIBRATED BUT NO LUCK. ANY HELP APPRECIATED. THANKS T
  • unisys12
    • 489
    Pull your developer assy and take a good look at the tip of the mag roller on the drive side. You will notice how it is pointed? That is for development bias contact. There is a roller bearing that rides in that shaft. If the shaft looks worn, as in "scared", you will have to replace the mag roller. Also check the bearings for the mag roller located in the developer unit.
    Hope this helps!
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
    • galexander37
      • 16
      Try the bias board and the drum might be worn down to the metal and causing an arch to the dev unit.
      g
      • T911
        • Jun 2007
        • 628
        It was the bias board. Thanks for help.
