ricoh mpc 2050
  • tulipano
    • May 2010
    • 124
    ricoh mpc 2050
    salve a qualcuno e' capitato in questa macchina ricoh mpc 2050 quando lancio per esempio 50 stampe me ne fa 20 poi 5 minuti di attesa e mi stampa le altre30.anche quando faccio 20 stampe e fotocopie si ferma sempre 5 - 10 minuti di attesa e poi riprende a stampare.
    grazie
  • teebee1234
    • Jul 2008
    • 1670
    Italian to English translation (by Google)
    prejudice to someone 'happened in this machine ricoh mpc 2050 launch when eg 50 prints makes me 20 then 5 minutes of waiting and I get 30. when I print 20 prints and photocopies always stops 5 to 10 minutes of waiting and then resumes printing.
    thanks
    Is the driver loaded on a server or local on a pc? Sounds like a spooling issue from the server. Is the data light flashing during this entire process? I would first connect my laptop directly to the mfp and print the same job or something similar. If it prints normally then you need to hand the problem back to the customer. I've seen servers with the hard drive nearly full, it took forever for print jobs to spool from it. I'm sure others will post more suggestions here soon.
    *Can you clarify whether it only occurs during printing only or does it happen in copying mode also. I made the above statement on the assumption it is occurring during printing only, but the translation makes it unclear. If it happens during copy mode also then we have a totally different problem.
    • mikadonovan
      • May 2008
      • 2931
      Sounds like the machine may be set up to recalibrate frequently to prevent copy quality from degrading.
      NEVER ASSUME ANYTHING
