Ricoh 1022 jams at reg roller and just says "copying"
  • DCW98
    • Jun 2010
    • 11
    #16
    SBCU is 1 of 5 boards in the back, so you got that one ruled out.
    Therefore only SBU could be the problem of SC193 in my opinion, it's the only step left in image processing.....
    SBU is also a common reason for giving SC101 so the link between the codes might be in this board.
    For info: The SBU is combined in the lensblock
    You got a tough one here i got to say, but i admire you perseverance :-)
    Please give update on your result...
    • Fearless V K
      • 620
      #17
      Goose Guide says...
      B022/B027
      SC 101
      - mirrors out of position
      - replace lens holder assembly with SBU board attached
      - replace power supply
      Don't take that toner with me!
      • copyaction
        • Oct 2007
        • 991
        #18
        It was the cable from the lensblock to the back of the machine.
        thanks again to everyone!
          • 23008
          #19
          Congratulations on a difficult fix. This is one of those that can drag out way too long. =^..^=
