lanier ld116 Line on lead edge.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    This machine has a line on the lead edge no matter which direction you feed it in. I cleaned the optics and was wondering if it may be the doc feed scan speed, showing the edge of the paper. Is this a common issue on this type of machine?
  • teebee1234
    • Jul 2008
    • 1670
    How's the registration? Do you get the line when you copy off the platen? If you overlay the copy on top of the original, is there much of an image shift? You may have to go into the SP mode and adjust the registration and maybe some edge erase.
    • nmfaxman
      • 1702
      I have had to readjust doc feeder registration from time to time on all machines.
      Ricoh is no exception.
      • Copylady57
        jerry, did ya try to print a counter list to see if it is nasty when not off the glass?
        marty
        • Fearless V K
          • 620
          Sounds like an ADF registration/erase margin adjustment should fix it.
          Don't take that toner with me!
